Does anyone have any idea how to refinish a plastic Kayak, paint or otherwise?
Thnaks, Scott
Plastic kayak refinishing
Scott
Have recently purchased Pearson Triton which I will be restoring over the coming months/years!
Summersdawn
Mark.Wilme
I used to paddle white water in the UK - most plastic kayaks these days are either linear or 'cross linked' polyethylene. They are going to be very tough to paint. It's going to be like painting King starboard or Tupperware.
If it's fiberglass however then normal painting applied, however they will get scratched up very, very easily.
If it is ABS...
I had good luck where I worked cleaning up the housing of our Bluefin Robotics AUV (had an ABS housing) simply by sanding. It seems that ABS oxidizes a small bit and changed the yellow to a browner yellow--wrong color for search and rescue in the ocean but I didn't chose it. I'm guessing that waxing after the sanding would have fixed the oxidization problem but it had bigger problems. I can't say I've seen this happen on anything other than ABS so good luck if its not that.
Summersdawn
Sorry it took so long, I had trouble finding the right article.
The article came out in the Spring 2006 Boatworks, on page 62 - entitled "Refurbishing a Plastic Dinghy". I saved the magazine specifically for this article. I don't know how well it works, but I thought it might be worth trying some day.
The article starts off by the usual surface prep - degreaser and a lot of sanding. Tthey didn't specifically mention which degreaser they used, try some in an inconspicous spot first to make sure it won't react with the plastic. More than likely the plastic is polypropylene, which is resistant to almost everything.
He next applied a binder called "Bulldog Bond*Flex*Tie-Coat". This was applied with a brush (he didn't specify whether or not it was thinned, but mentioned phoning tech support and talking to a very helpful technician). This appears to be a binder used frequently in the autobody industry for getting paint to stick to plastic body panels.
The binder cured for 30 minutes, and then he proceeded to pime. He used "West Marine's house brand", but didn't specifically mention which type. I would assume after using the binder, you would probably have to use a single part primer/paint (just a guess on my part, I'm sure there tech support could provide a definitive answer).
If you try this system, let us know. I'm curious to see how well it works.
Rick
Summer's Dawn
24 San Juan #380
Summer's Dawn
24 San Juan #380
