As it is lay up season and the boat is out of the water I took the pump off today (4 bolts and two hoses). I already had the impeller out as I take this out every year so it doesn't get mis-shapen.
I am trying to figure out 2 things :
1. Is this likely to be a Westerbeke part or a stock Johnson pump or something - I can find no part # stamped anywhere on the thing? It's going to take some cleaning up to find a part number on it.
2. On the "back" where it bolts into the engine there is a kind of fibrous, oily sludge - as if something has been churned up and ground into tiny bits with the oil - it's not metallic or anything. I wonder if there is some form of rubber seal in here that's got ground up or at least a little frayed and the pieces got carried into the oil causing this goo (you can see it in the second photo) and also the drip ?
Anyone any experience with these or point me to a schematic, a web site or anything ?
Also I read online about a rebuild kit and also sometimes about the rebuild kit not being needed and all that is needed is a shaft seal - any insight ?
Much obliged.
Mark
