This is quite uncomfortable for more than an hour or two - even doubling up the seat cushions doesn't help much (and also cancels out the benefit of the coamings as backrests).
The cockpit well is also too narrow to stretch out my legs, with the result my knees are pretty sore by the end of a long day on the water.
I had come up with a plan to drop down the cockpit sole about 6".
This would also fit in nicely with installing an engine access hatch, a la Contessa 26, at the same time:
(which also appears to have low cockpit seats, now that I look at it again)
What I have just realized, though, is that (DOH!) - there's a reason the cockpit is not deep. One more picture:
Without getting out to the boat and measuring exactly, I am now pretty sure the cockpit sole couldn't be much lower without going below the waterline. Chances are the leeward side is already very close, since she sails fairly well heeled over.
So far, I am thinking that I don't want to give up the convenience and safety of a self-bailing cockpit, BUT
- my chances of getting pooped are very small
- cockpit scuppers drain notoriously slowly anyway
- I could install scuppers above the waterline (i.e. on the sides of the cockpit), so that it would still be self-bailing except for the portion below them (~6", maximum). This would leave roughly 150 lbs of water, once the rest slops out or drains away.
The remaining portion could be drained to the bilge. I don't think this is a great idea, but it might be better than having it in the cockpit, where it would upset the trim of the boat more. (It would have to be plugged until the rest of the water was gone, to keep too much of it from going to the bilge in the first place).
Anyway, this all sounds unusual enough to make me pause and wonder what I may be overlooking. I don't really want to go the "other way" by building the seats up, since the boat sails on her ear. The depth between the seat and the coaming really does help stay in the boat (when winching in the jib on the leeward side, for instance).
But I am very open to any advice or counsel here - my knees are getting creaky, and I am getting tired of listening to their complaints!
