Gooseneck/boom height on a Triton?
kabauze
Boat Name: Nevermind
Boat Type: Pearson Triton #450
Post by kabauze »
I've got a question for the Triton gang. Nevermind is a West Coast boat with a fractional rig. At some point a previous owner replaced the original mast with a tapered spar from an early East Coast boat. In a few weeks I'm going to unstep the mast to refurbish it, and I want to convert the sliding gooseneck to a fixed position. But what's the right height of the gooseneck from the deck? Another thread in the forum (http://triton381.com/forum/viewtopic.php?t=76) lists one boat as having its lower band 2'9" off the deck. Is that what others have? What height have you found convenient?
I'm hesitant to simply reuse the position I have now. The boom seems low, and my main is cut too long; the boom has to hang very low to get a full hoist. I know the system's not right.
The Triton sailplan is beautiful but doesn't show a gooseneck height, only a luff length for the main. I suppose I should measure the mast height and come up with an answer myself. Hmm, I'll make some measurements today.
Thanks -
Todd
2'-9" (33") seems about right. It's been a while since I measured mine, and I don't recall exactly, but that seems spot on. I know it was just under 3'.
I originally had a black band on the spar at that location, and that's where my new gooseneck is installed. I have since sanded and painted over the original band.
That roughly corresponds with what the drawing shows, too, though I didn't try to scale it. But visually, what the drawing shows is how mine is set up, and where the black band is/was.
Will you be getting a new mainsail once you relocate and fix the gooseneck?
kabauze
Oh well...
Post by kabauze »
Well, I took some measurements this afternoon down at the boat. Needless to say, it was an afternoon of surprises!
The mainsail tack, which is where the black band would be if I had one, is 31" off the deck. That means it's a couple of inches lower than it should be. That explains why I thought the boom was low.
The bigger surprise (isn't there always a surprise!) is that the main sheave is only 33'2" off the deck, and the whole mast (including masthead fitting) is probably 33'10". Obviously I won't be getting a 33' luff on my main without the boom sweeping the deck!
My first reaction after taking the measurements was to locate the tequila hidden in the bilge, but after that, I started thinking about something the previous owner had told me. He said, "The main is from a masthead Triton and it's a little long, so the boom hangs a little low". This never made sense to me since masthead mains have a shorter luff than the fractionals...but now, I see. I have a mast that's only as high as the mast on a masthead-rigged Triton. Sheesh.
Now that I think about it, this probably explains a lot of the weather helm that the boat has under certain conditions. In essence, I have a masthead rig but am running very small jibs on it (due to the fractional rig).
Wow, nothing is ever what it seems with these boats!
Thanks, Tim, for your reply.
Case
Post by Case »
Oh yes... That is the charm and annoyance of a Triton. From my incessant reading about the Triton, I recall that many of the West Coast Tritons did not have a consistent rig size. Some was fractional, some was masthead and the height varied. Perhaps your boat was rigged for San Francisco and got a shorter fractional rig instead of the standard masthead rig or the taller East Coast fractional rig.
Weather Helm? Well... use a bigger headsail or a smaller main. That and the usual fiddling with the rig is about all the advice I can offer you. Since it looks like you're getting a new mainsail and it will be slightly smaller than the old one, you might already be on track on improving the weather helm.
- Case
The yawl-rigged fractional Triton also had a shorter mainmast, which seems to roughly correspond with the shorter west-coast fractional sloop rig as well.
If your spar came from an east coast boat, it was likely a yawl. Or so the anecdotal evidence would seem to indicate...
Boat Name: Hirilondë
Post by Hirilondë »
My Renegade came with a fixed gooseneck fitting. Whoever installed it placed it too high. When my main is raised all the way the head board and top batten foul on the back stay. I am switching to a sliding goose neck. What reasons do people have for choosing one over the other (fixed vs sliding)?
In my case I want to be able to raise the boom higher than sailing height for the boom awning I want to have made next year. I am having a zipper installed on my new dodger this year to attach the awning to.
Sliding goosenecks are tricky with a rigid vang, if you have one. It can be made to work, but it's less than ideal.
I'd think you could have the top of the sail trimmed down for a lot less hassle and money than converting the gooseneck.
