Removing sticky paper cover from Lexan
Triton106
Hi All,
I recently bought an old engine instrument cover from Minney's. The protective paper cover on the Lexan is very diffifult to come off. I don't want to use scraping knife because I don't want to accidentally scratch the Lexan. Does anyone one know a way to remove the paper without demaging the Lexan?
Thanks and regards,
Thanks and regards,
Ray D. Chang
Triton 106 in Berkeley, CA
- Boat Name: Rambunctious
- Boat Type: J/30
I would try soap and water first. As Rachel indicated, lexan is very sensitive to solvents (particularly acetone). The adhesive that holds the paper to the lexan is very mild, so perhaps soaking it in soapy water will make the job easier.
I don't think Windex will haze lexan, but I would start with something milder just in case.
Failing the water, soap and adequate time:
Paint thinner will dissolve many such cements, too. You'd need to get the lense out to soak it or be very sparing to be sure it did not get inside and find something inappropriate to solve.
Lacquer thinner will probably dissolve the plastic, but you might get away with it working fast to clean the last of the goo.
Ahh, yes! Goo-B-Gone is worth a try as well.
- Boat Type: J/30
I would stay away from real solvents.
After I replaced the portlights in the saloon, I painted the interior. I had two paint runs down one of the portlights. I must have been a bit punchy from the fumes, because I did not notice it until the next day. I didn't want to scrape the lexan as I was afraid of scratching it. So, I tried acetone.
Dumb, dumb, dumb.
It clouded the entire portlight instantly. Once that happens, there is no fix; you have to replace the piece.
Dumb, dumb, dumb.
Triton106
Thanks everyone for your ideas. I will try hair dryer and water/soap.
I am not sure about paint thiner. I was painting my deck a couple of months ago and must have dropped a couple of drops of paint thinner on my hatch and overnight resulted in cracks in the Lexan hatch.
Ray D. Chang
If you scratch the polycarbonate try this stuff: http://www.cruisercustomizing.com/detai ... t_ID=10421
I did the corners and bungs of a new smoked polycarbonate top for a teak frame hatch for a Hinckley by sanding in stages from 80g through 2500g wet paper then finished with the Novus polish. It came out optically clear. It is a sick way to spend 3 days work, but the stuff will bring back scratched plastic.
Triton106
Hi All,
I thought I will let everyone who helped with free advices know how it came out. I tried hair dryer and it did not work effectively. So I next soaked it in warm water and, viola, that is all it took to get the sticky paper off lexan (with some scrubbing using soft sponge).
Thanks everyone for your help!
Best regards,
Best regards,
Ray D. Chang
