In the shared details department, I include a description of a LeComte North East 38 fireplace stack fitting and wonder about other boats of the day.
Our fitting is a welded-up stainless flanged thing. It has a bit of pipe extending down outside the pipe leading down to the fireplace; the outer edge of the flange is turned up about 1". When needed, the johnny noble is stuck onto a bit of pipe extending up about 1 1/4". Normally, the smoke pipe is capped with a heavy stainless lid held on by gravity and a friction fit.
The two upturned features means that the fitting can hold water about 1" deep. Do you suppose this is to be filled with water to keep the deck around the stack fitting cool? Otherwise, why would they not have drilled the upturned flange to drain?
Fireplace Johnny Noble Fitting
Well it's appropriate that you posted that..... Charlie.
It'd be interesting to see a photo of your set-up, Quetzal.
Here're a couple of a fitting sold by Navigator Stove Works (as Britton posted once before) - it sounds a bit like the one you describe, and has the water trap to keep it cool.
You can find other chimney accessories here, on their website (and their nifty cast iron stoves elsewhere on the site):
http://www.marinestove.com/Accessories.htm
