And the matching anchor lamp.
Weems & Plath Yacht Lamps represent the culmination of more than a century of practical use and development.
Crafted of solid cast and tooled brass, with original finish or chrome plated, this solid brass high quality lamp will enhance the decor at sea or on land.
* Stand alone on a table top, hanging gimbaled, or hung from a wall bracket
* Oil container capacity: 2 oz.
* Burn time: +/- 12 hours with clean burning Weems & Plath? lamp fuel
I admit that I do have some reluctance in carrying another type of fuel so I have been searching for some alternatives and I came across these solar powered lights. They seem quite interesting for using as the anchor light. They don't give them away but then again they don't give away the oil lamps either.
Lacquered and polished. Use lamp oil or kerosene. 10 Oz. Oil capacity, burn time about 40 hours large/30 hours small.
Model 501
Up to 1 nautical mile (1.8km)
The Model 501 is a multipurpose solar-powered marine light suitable for virtually any low intensity navigation or hazard-marking requirement.
What sets the 501 apart from any other light is its unique encapsulated design. The unit is completely waterproof, vibration proof and vandal resistant. It is designed for autonomous operation without any maintenance (i.e. bulb or battery replacement) for up to 5 years.
The 501 is available in red, green, amber, white and blue LED output colors using a clear lens. For daytime indication, colored lenses are available on request.
APPLICATIONS
* Mooring buoys
* Research buoys
* Dredging lines
* Oil containment booms
* Aquaculture farm perimeters
* Private and commercial docks, swim rafts, etc.
* Breakwaters and channel markers
BENEFITS
* Quick, non-technical installation.
* Low capital cost.
* Pays for itself within the first year of operation in the form of reduced installation, maintenance and servicing costs.
* Reliable operation 365 days per year.
* Operates at nearly any location on earth.
FEATURES
* Uses Carmanah's proprietary MicroSource? solar LED lighting technologies.
* Completely integrated, self-contained, waterproof and compact.
* Polymer encapsulated design and solid-state electronics make the 501 extremely durable and vandal resistant.
* Installs in minutes using three screws or bolts. No external wiring, cable trenching, etc.
* Turns on automatically at dusk and off at dawn.
* Uses LEDs (light emitting diodes) with approximately 100,000 hour lifespan. No bulbs to replace... ever.
* Available in red, green, amber, white and blue LED output colors - allowing for virtually any marine lighting applications.
* If required for color indication when off, the 501 can also be ordered with red, amber or blue lenses.
* Can produce one of seven IALA standard flash patterns (including steady on)
* Intelligent electronics ensure the batteries will last up to five years without maintenance or servicing.
* Manufactured under ISO 9001:2000 Quality Assurance System.
* Three-year warranty.
So does anyone out there have any experience with going in either of these directions? Or even better, am I missing some other option?Model 601
Up to 2 nautical miles (3.6km)
The Model 601 is a multipurpose solar-powered marine light suitable for virtually any navigation or hazard-marking requirement up to 2 nautical miles in range.
To-date, more than 40,000 units have been used around the world for all types of industrial/commercial applications.
Using an array of ultra bright LEDs (light emitting diodes), the 601 can produce light output in five colors that meet the international chromaticity requirements for green, red, amber, white and blue. It can also produce all IALA standard flash patterns and custom patterns can be special ordered.
The 601 charges during the day, even under cloudy conditions, and turns on automatically at night. It also features sophisticated microprocessor intelligence that enables advanced light output control and battery power management, as well as precisely controlled flash rates.
APPLICATIONS
* Small safety / hazard marking buoys
* Low range navigation buoys
* Research buoys
* Private aids to navigation
* Port and marina entrances
* Channel and canal markers
* Offshore oil & gas infrastructure
* Public piers, docks and marine walkways
* Boat and barge terminals
* Breakwaters and all types of marine infrastructure
BENEFITS
* Minimal capital cost.
FEATURES
* Polymer encapsulated design and solid-state electronics make the 601 extremely durable and vandal resistant.
* Turn on automatically at dusk and off at dawn.
* Available in blue, red, amber, white and green LED output colors - allowing for virtually any marine lighting applications.
* If required for color indication when off, the 601 can also be ordered with blue, red or amber lenses.
* Can produce any flash pattern required (including steady on)
* An optional infrared programmer is available to change flash pattern, change intensity level, activate/deactivate the unit and check battery level for current capacity.
Bill
Lopez Island, WA
