Priming before interdek
Capn_Tom
- Boat Type: Westsail 32
I am completing the prep work in preperation for painting my cabintop. I am using Perfection cream on the smooth areas and interdek beige on the molded non skid. I realize that interdek does not require a primer but I am considering priming the whole surface with epoxy primekote to fill any gelcoat cracks. The upside is that I have to prime the smooth areas anyway so it will be easier to do the whole area. The downside is that I can't think of an effective way to sand the molded non skid. Thoughts theories and recommendations would be appreciated.
- Boat Name: Rambunctious
- Boat Type: J/30
This is purely a personal preference, but I don't care for mixed aggregate non-skid paints, like Interdeck, over a molded non-skid pattern. It looks like a job done quickly and cheaply, even though it can still be a lot of work. If you really want the Interdeck, then I would suggest sanding the molded non-skid off entirely with a DA sander and 60 or 80 grit discs. If you want to keep the molded non-skid, then use a paint without the aggregate mixed in. This is, of course, my opinion only.
I'm unsure of the best way to prepare a molded non-skid section for paint without compromising the non-skid texture, though.
In my case I found the molded non-skid to be quite soft. 80 grit on a DA sander make short work of it. 40 grit, followed by a brush with 80 grit made really quick work of it.The downside is that I can't think of an effective way to sand the molded non skid
A couple of years ago I wanted a quick and dirty solution so I just painted over the molded pattern. Bad idea, It became VERY slippery after that. The molded pattern did not come close to providing enough grip through the paint.
Summersdawn
