Clean Bilge
Marshall Wright
- Boat Name: s/v Sunset
- Boat Type: Pacific Seacraft 25T
Clean Bilge
Now that I have the bilge plug out, I'd like (once it gets a little warmer) to really clean out the bilge.
I've got some access difficulties with accessing my bilge. I've pulled my water tank so that area is accessible. But that compartment is separated from the fuel tank by a below-sole bulkhead. And the fuel tank is located over the deep bilge and is so tight that only 1/4" gaps exist around that tank. Another below sole bulkhead separates the fuel tank compartment from the one below the engine which has a nice fiberglass below engine oil tray - all this effectively seals off the bilge. My only access below the motor is through a 1-1/2" hole in the tray that my manual bilge pump pipe feeds through and back through a small slot at the stern where the shaft exits the hull.
Couple of questions. I'm considering pulling the fuel tank to clean that compartment. Do you know whether businesses actually come to a boat and will pump out a tank? Under what name in the Yellowpages????
I'm considering using a low psi pressure washer. Are they available where you can add cleaning agents or actually heat the spray to help clean off any grease?
I've read previous posts. I'll try flooding the bilge with cleaner after putting Sunset back in the water and pump out after it has sloshed around for awhile. But before that, I'd like to do a thorough cleaning and flush out most of the 30 build-up while she is on land and I can capture some of the runoff.
Advice, equipment I might consider/rent, chemicals to use, etc. most appreciated.
Marshall
Marshall
The boatyard will know who to call for the tank pumput. If it's a well-run yard, they probably don't let just anyone on site to do such work.
Yes, some pressure washers have integral detergent dispensers, but I've only ever seen this on the low-powered ones. A TRUE pressure washer will strip paint at ten-inch range just with the pressure, so detergent is really unnecessary.
Adding heat to a pressure washer brings it into the realm of a "steam cleaner", which is a whole other animal, capable of stripping paint from ten FEET away, and I would not advise turning this animal loose on the inside of a boat. I like my skin just where it is, thankyouverymuch.
Marshall Wright
Pressure Wash
Figment,
OK, the steam cleaner is out.
I can borrow a Red Devil ??? pressure washer. May generate +- 150 psi??? I could push the wand down below into my bilge.
But is this going to be effective? Would getting my hands on a detergent model be better? Is 150 psi damaging?
Marshall
Marshall
Some "real" gasoline-powered power washers feature a little fitting where you can connect a hose to a bucket of cleaner or what have you. (I have one of these.) It's not necessarily that effective; you're just as well off sudsing the area up on your own first, then using the power washer to clean it afterwards. Or even no soap at all: that depends on the specifics of the case, I'd say.
I could not scrub the entire bottom of the deep keel, either. About half is under the monel fuel tank and that tank is glassed in place. I settled for spraying with an ordinary hose, added soap, and a wet-or-dry vac. Since the remaining half of the offending surface is about 4' below the sole and mostly under the engine, scrubbing was out. Even so, the boat no longer smells of bilge, and three seasons later, I can still see clean fiberglass when I vacuum it dry at the end of a season.
My power washer's a 2200 psi gas powered thing with a siphon pick-up for soap (that doesn't work, by the way). You can certainly chew up softer surfaces, like unfinished wood and your shoes, but fiberglass and gelcoat are pretty resistant to damage. My wife never allowed me to use the washer inside the boat; it would send spray and removed stuff all over everywhere.
Maybe one day I'll figure out how to get that Atomic 4 coil out from under the tank; my magnet wasn't up to the task.
Maine Sail
Re: Clean Bilge
The easiest way is to buy an electric 12v fuel pump, some hose, the right fittings at an auto parts store (about $15.00) and a 6 gallon jerry can about $8.00. Empty it six gallons at a time and offer the fuel to another boater or for someones oil furnace or boiler. Simply remove your fuel line and pinch it with needle nose vice grips and plug your new "pump" set up into the fuel tank and turn it on to fill the jerry can..Marshall Wright wrote: Couple of questions. I'm considering pulling the fuel tank to clean that compartment. Do you know whether businesses actually come to a boat and will pump out a tank? Under what name in the Yellowpages??
Marshall
Over the years I have removed more fuel tanks than I care to count and this is how I've emptied them...
Ancient Race
Ganges #363
Clean Bilge
This is a great product. I've used it to siphon fuel into the tank, haven't tried it going the other way but it should work just as well. Super easy, no mess.
http://www.simplesiphon.com/products/
Tim Mertinooke
