I am having a problem with paint adhering to my lead keel, so after pressure washing the keel, I used an abrasive grinding disc and removed most of the remaining paint.
Is there a special primer which I can apply to the lead before fairing, which will allow the bottom paint to stick?
Do I need to go the Interlux 2000 route to solve this problem?
Has anyone tried the Marine Bondo to fair a keel?
Priming and Fairing a Lead Keel
mhdyachtsman
- rshowarth
Keel
On our Mariner Cast Iron swing keels, we used thickened epoxy.
I have heard of some using POR 15 to paint as a primer.
I do not know if it might work for you.
Read
Catalina 27
O'Day Rhodes 19 Custodian
Catalina 27
One thing to keep in mind is that lead oxidizes very quickly. So you need to re-grind it to bright white metal immediately before applying whatever your chosen product is--fairing compound, primer, or paint. A nice coarse grinding also helps provide "tooth" for better adhesion of whatever comes next.
"Marine" bondo is cheap polyester just like the auto stuff. Don't use it or any polyester for filling. You'll have much better bonding and overall success using epoxy fillers, particularly on a lead keel where bonding strength is the key.
If you're going to fair, then apply the fairing compound before any paints or primers; other wise, the fairing compound adheres only to the paint and therefore relies entirely upon the paint's bond with the substrate.
- Wood Whisperer
To get a good bond to lead, the Gougeon's recommend sanding with a rough grit THROUGH the wet epoxy. Then you have zero chance of oxidation on the lead ( or other metal you are bonding).
Once that coat cures to a green stage, you can apply the epoxy filler.
Works well on cast iron surfaces also.
On our own keel (cast iron) we then coated with Coal Tar epoxy and painted with anti fouling.
mhdyachtsman
