Prop Shaft Cotter Pins
- Peter
- Boat Name: Pagan
- Boat Type: Albin Ballad 30
I've finished my beaching legs and am getting ready to install a new prop. Just wondering which would be a longer lasting cotter pin: silicone bronze or stainless steel? (I can't find any monel ones around here :-( )
feetup
Silicon Bronze sits midway between passive 316 stainless, and active 316 in the galvanic series for stagnant (ie. low oxygen content) seawater. If you use a 316 stainless cotter pin in a bronze shaft/nut be sure to bend the ends snug around the shaft/nut so that the pin cannot work and wear away the passivating layer. Even if it does wear away the passivating layer it will last for a lot longer than you need it to in the relatively oxygenated water of Pedder Bay. Likewise silicon bronze.
I would say it is an either/or.
Feetup
After all's been said and done, there's a lot more said than done.
Feetup
