Traditional bronze hand pump in galley (plumbing question)
Scout
Someone has given me one, it's beautiful. Could I use this in lieu of a faucet and pump the water through using the foot pump? (I do not have hot water).
feetup
I don't see why not. You may have to remove the foot valve in the pump, essentially turning it into a spout, but the foot pump might just have the pressure available to push past the valve. If you can overpower the valves, you could have a double system where you could suck through a check valve and bypass the foot pump, giving you a hand pump or push through the hand pump valve with the foot pump.
I must admit a little jealousy. Sounds beautiful. Kind of Slocum "Spray" or early Herishoff.
Feetup
Feetup
Capn_Tom
- Boat Type: Westsail 32
There is an old brass galley pump on ebay right now that is beautiful. The spigot design doesn't seem practical though. http://cgi.ebay.com/ANTIQUE-BRASS-WOOD- ... dZViewItem
BALANCE
Ah, it's the little things in life....
Despite spending two days on my side yanking out old caulk under the caprail, recaulking a hatch cover which was reminiscent of making mud pies (I was a little heavy handed), going to bed exhausted and discovering it was wet. There's more but I won't bore you.
Here is the source of some smiles:
S/V BALANCE
Westsail32
Westsail32
