I've got a new Naqualift muffler with a side angle in, and top out. The cylinder (body) is 6.5" high, and about 6.5" in diameter. It's pretty small to begin with, but that's all I have room for. Based on this, I calculated (pi x radius^2 x height) the volume of the muffler (thinking water holding capacity) to about 215 cubic inches, or just short of 1 gallon (231 inches). That would be fine.
Now, when I look at the angle inlet tube into the muffler, I see it reaches to within about 2" of the bottom of the cylinder. I don't see any vent inside there, or anywhere in/on the muffler. I'm concerned upper area of the muffler will be just a trapped air bubble, effectively reducing the volume of water the muffler can hold before it starts sending water up to the exhaust manifold. If the effective net area is only 2" high, instead of 6.5" the water holding capacity is reduced to just 66 cubic inches, or about a quart, meaning 3/4 of this muffler will always be full of air/exhaust gas that can't get out, and not available as water holding capacity.
Based on this, I got a measuring cup and started pouring water into the outlet side of the muffler. It started to overflow and come out the inlet side at 36oz, far less than the 128oz (1 gallon) range I'd hoped for.
I've gone ahead and drilled a small hole through the inlet tube wall just inside the body of the muffler to form a passage/vent from the highest internal part of the inlet tube. This will relieve air pressure of the bubble to the height of that point into the inlet hose side, raising the water level inside the muffler, but it still looks like the top half, or third, of this muffler will be full of trapped air/exhaust.
Does anyone know if there is something in these mufflers (Vernalift or Naqualift with angle in) to prevent the upper section of the muffler from trapping air that displaces water?
All input much appreciated,
John
