Okay, I may not know everything but am getting ready to rebed the deck hardware on our club boat. One of the other boats just replaced their rope clutches and when they bedded it they put it on but didn't completely tighten down the fasteners so the bedding could cure.
Now this just seems a little odd to me. Or maybe I'm thinking back to the days of when I bedded things on a woodie w/ Dolfinite.
Do I REALLLLLLY want to let the bedding compound set up a day or so before tightening the fasteners or is this just bunk? Would seem to me this could potentially leak.
What say y'all?
Rebedding ?
Sailordave
- Boat Name: Rambunctious
- Boat Type: J/30
The idea is that it creates a better gasket-like seal. The problem is that if the fastener moves at all, it breaks the seal and you've just invited a leak. I say use plenty of sealant and fully tighten all the hardware at once.
The way to do it, if someone was really inclined, is to use a screw driver to hold the fastener absolutely still and tighten the nut from below. I'll repeat that this is entirely unnecessary and much more likely to invite - rather than prevent - a leak.
Re: Rebedding ?
No!Sailordave wrote:Do I REALLLLLLY want to let the bedding compound set up a day or so before tightening the fasteners or is this just bunk?
Sailordave
