Before I jump into this, I want to clarify my understanding of mix ratios for paint.
Whereas 1:1:1/2 equals 1 gallon paint and one gallon converter, does the 1/2 (reducer) number equal 1/2 gallon? Then does the 25% number reflect the ratio of reducer to the total volume of paint and converter?
Any other pearls of wisdom applicable to spraying in 90 degree temperatures and high humidity would be welcome.
Chris Miller
1971 Seafarer 31 yawl
Lloyd, Florida
1:1: 1/2
margitchris
- Boat Name: Moonshadow
- Boat Type: Seafarer 31 yawl
Re: 1:1: 1/2
Anything that is measured in parts means the amount of each in reference to each other, not the final product. So 1:1:1/2 could be done as 1 qt. 1 qt. and 1/2 qt.. Or any quantity for that matter, ounces, barrels, bathtubs full or any other liquid measure. If the reducer is given as a percent, it means percent of the total paint ready to be reduced. In other words, mix the paint components, then add reducer as a percentage of the total quantity of paint.
As to spraying: my experience is way too minimal to offer advice, just a "good luck" is all I can offer :)
