I have this winch fitted to my 1978 Bombay Explorer. It lifts and lowers the swing keel on a wire.
Can anyone identify the make for me please. As far as I can see there are no numbers or letters anywhere but I have not dismantled it. [ I am a founder member of the 'If it aint broke don't fix it' club.
It operates in an unusual manner. I can wind 3 to 5 turns in either direction before it gets very stiff, I then wind 1 or 2 turns in the opposite direction then it frees off and I can wind 3 to 5 turns again. It does this if there is load on the cable or not. Is this normal??
Can anyone identify this winch please
Re: Can anyone identify this winch please
I don't want to chase you off from here (far from it!), but you might ask on the Trailer Sailor forum. I know there was just a long discussion or two on swing keel winches/replacement/brands within the last week or so.
(Of course someone might be along here, too :)
http://bbs.trailersailor.com/forums/tra ... /index.cgi
TQA
- Boat Name: No Name Yet
- Boat Type: No Boat Yet
I suspect that this was a halyard winch for a wire halyard rather than a trailor sailor winch. I have had a couple of trailor sailors and the winches were much smaller and looked less expensive.
This is a pretty serious lump of bronze and looks very well engineered.
BTW the boat is a 44 foot ex IOR design and the swing keel is a large weighted foil which increases the draft from 5 to 9 1/2 feet.
Oops! Definitely not a trailer sailor then. I am sorry for the inappropriate lead :blush:
Mario G
- Boat Name: Don't Wake Me / Shaken Knot St
- Boat Type: Chrysler C-22 &C-26
Souinds like it could use a good taking apart cleaned and greased. You want to look at the grears if you haven't seen them before. I would also question the cable if I didn't know its age.
A 44' swing keel sounds sweet, all that room with out grounding. Can you post a picture?
TQA
The cable was renewed by the previous owner. I am reluctant to strip down the winch as it does work at the moment and I can raise and lower the foil.
But as I said it's operation does not strike me as normal and there may be some lurking problem which requires spare parts or some arcane adjustment. I would like to be prepared before I delve into it's innards.
I am heading down to Grenada and will be thee for a while including a haulout so I have an opportunity to work on the winch.
I am very pleased with the boat on the whole I wanted something faster than my previous heavy 38 foot steel Ryton 38 and she can fly. I also needed something that I could singlehand.
