I have a w21 in my B32. needs a fresh water pump.its a kubota block. went to tractor store today to check on parts the pump for a d850 has 4 bolt holes I have 6. the W 27 also has 6 holes and is almost the same engine. does anyone know what block a 27 is or where I can get that info
Thanks !
westerbeke- kubota prts info needed
Re: westerbeke- kubota prts info needed
I have a 1982 W27 (not the 27A) in my7 Sabre 34. It is a Mitsubishi block.
lowufo
- Boat Name: providence
- Boat Type: bristol 32
hi dick
do you know what block you w27 is ? maybe i can hunt down a 27 pump > yours a 6 bolts pattern ?
thanks
thanks
I don't know what the Mitsubishi block number is and I am not near my boat now to check the number of bolts. Try Torreson Marine's Diesel Direct site. They have parts diagrams and are a Westerbeke dealer. Here's a good starting point: http://www.marinedieseldirect.com/catal ... alog=32139. Good luck
