Removing this sticky fuzzy junk
JohnD
- Boat Name: undecided
- Boat Type: Pearson Triton EC #234
I recently pulled off an old vinyl like covering from behind the backrest on my boat and was left with a fuzzy material stuck to the fiberglass. I tried to sand it off, but that didn't work at all. I then moved on to soaking it down with a natural paint remover and attempting to scrape it off. This got most of it, but I'm still left with some funk that I need to remove to sand everything down and repaint it. Anyone dealt with this stuff before or have a suggestion on the best way to remove it?
Re: Removing this sticky fuzzy junk
From what I have seen of other Tritons, this is not a Triton/builder feature, but a material some previous owner installed.
Not that that changes your desire to remove it (and I would too).
Here are some solvents I have used to remove sticky gunk from fiberglass:
1) Denatured alcohol
2) Acetone
3) 3M Adhesive Remover (citrus, black aerosol can with multicored stripes)
3) Interlux Solvent Wash 202
4) Lacquer thinner
I tend to try #1 first as it seems the least noxious/toxic. Recently I had to remove some old contact cement from fiberglass and it just would not yield to any of the above. Finally I found that a one-two alternating punch of 3M Adhesive Remover and denatured alcohol did the the trick. Whew.
If the residue is somewhat hard/dry, then there is potential for sanding (which I see you have already tried) or scraping.
2) Acetone
4) Lacquer thinner
hriehl1
- Boat Name: s/v Mooney Hahn
I have had decent luck with Goof Off and similar products; adhesive removers available in the paint departments of hardware stores and home improvement chains. It is very effective on duct tape and masking tape adhesive residues.
s/v Faith
- Boat Name: s/v 'Faith'
I would first try denatured alcohol. It works great, and is pretty tame.
Then I would go to thinner... if that does not work use acetone.
(with gloves and ventilation of course).
1964 Pearson Ariel #226
Referred by;
www.sailfar.net
and
www.pearsonariel.org
Referred by;
www.sailfar.net
and
MichaelD
- Boat Name: Halcyon
- Boat Type: Pearson Vanguard 32
If it's contact cement on roving.....use a wire wheel on a drill.
