As some of you may know from my posting in Projects that I am repowering my Triton (#106) with a Yanmar 2GM20 and plan to replace cutless bearing, stuffing box hose, and coupling at the same time. Since the boat is in the water now I can't measure the stern tube to confirm the inside diameter. I
plan to reuse the prop shaft which is 7/8". However, 7/8" cutless bearings come with three outside diameters. All east coast Triton sources I find on the web tells me that the stern tube inside diameter is 1-3/8". However, I would like to confirm if west coast tritons also have the same diameter before I place the order which I need to do before hauling the boat out.
I also read on Tim's and Nathan's rebuilding logs that the east coast Triton stern tubes have outside diameter smaller than the standard stuffing box outside diameter (1-3/4") for 7/8" shafts. In Tim's case the stern tube outside diameter is 1-1/2. Do west coast Tritons have that problem too?
Thanks very in advance for your help!
West Coast Triton Stern Tube Inside and Outside Diameters
Triton106
Ray D. Chang
Triton 106 in Berkeley, CA
Triton106
Re: West Coast Triton Stern Tube Inside and Outside Diameter
I have confirmations from two west coast Tritons, #150 and #259, that the stern tube inside diameter is 1-3/8". I have not haulled out Triton106 yet and will confirm it (or report a different size).
Ray D. Chang
