How do you cut balsa without it coming apart?
My last (and first) foray was cutting round plugs and it turned out ok but I know there has to be a better way. I used a jig saw last time and it was a struggle keeping the balsa together. My idea is to use clamped sacrificial luan. I will be recoring my sidedecks in the coming weeks and I sure would appreciate any suggestions/secrets that would make this part of the process a little bit less stressful.
Cutting balsa
Surveyor
- Boat Type: Alberg 30 #329
Cutting balsa
Jim - Bahala Na!
http://svcookie.blogspot.com/
bigd14
- Boat Type: Ericson 27
Re: Cutting balsa
You should be able to use a sharp utility knife (assuming its end grain balsa).
Doug
Doug
Doug
1972 Ericson 27
1972 Ericson 27
sscoll
- Boat Name: Medora Jane
Re: Cutting balsa
Doug's right, use a knife. Reserve your "stress" for NOT CUTTING YOUR FINGERS OFF.!!!
Re: Cutting balsa
I like a relatively dull fillet knife... Grin.
Balsa shears easily, and the round shape of the blade makes it easy to cut around corners. (Not round corners, but around them... bigger grin.)
- Wood Whisperer
Re: Cutting balsa
There are also knife blades that go into jig saws. I use them for cutting foam. Those should also do a great job
Surveyor
Re: Cutting balsa
Thanks everyone for the replies. I appreciate not being flamed for asking such a basic question too!
My memory is not what it used to be, for various reasons, so I looked back at the pics I took when I did the 4" disks previously. As it turns out I used a utility knife to shape up 4" squares cut with a jig saw. I was 1/2 way to balsa cutting nirvana!
Jim - Bahala Na!
