I bought a Cape Dory 36 that needs a little work. On the short list of things to fix is the engine bed/bearer that's rusted to the point it's about to drop the old Perkins down onto the hull. The original bed is a tubular steel structure glassed to the hull, and is now failing badly. I'd like to cut the glass tabbing that holds the rusted old structure to the hull, and build an entirely new structure that won't rust into dust over time. And, I'd like to take advantage of modern materials.
Would it be horribly wrong to build a new engine bed from structural fiberglass (FRP)? I've never seen anything stick fiberglass together like 5200, so maybe that could play a part here. Essentially I'd be using the old steel frame as a model to fabricate a new FRP engine bed, then glue it down to the hull with 5200.
I like the square tube FRP, but the temperature range for FRP looks low (140°) - maybe Garolite instead?
Any thoughts? Advice?
John
McMaster-Carr's FRP & similar: http://www.mcmaster.com/#plastic-rectan ... ng/=jg7e5r
McMaster-Carr's data sheet on FRP and similar materials: http://www.mcmaster.com/#8549kac/=jg78vk
McMaster-Carr's stuff on Garolite: http://www.mcmaster.com/#grade-ce-garol ... ng/=jg7w69
Engine Bed Construction
John, CD28
- Boat Name: Tiara
- Boat Type: Cape Dory 36
Re: Engine Bed Construction
There's nothing wrong with using FRP for the new bed logs, I would grind the hull clean and then add tabbing to attach the bed logs to the hull using several layers of bi-axial glass cloth and epoxy resin. Do not use polyester resin as you will only get a secondary bond. This should be a fairly easy project once the diesel is out of the way.
Good luck
Good luck
LazyGuy
- Boat Name: Paper Moon
I agree with Early Light. Skip the 5200 and go with epoxy. Set it in thickened epoxy then tab it in with biaxial and epoxy.
Dennis
Dennis
Tallystick
- Boat Name: Nostalgia
I used white oak bedded with thickened epoxy, then glassed it in with epoxy. My boat has metal brackets the motor rests on, kinda like the L shaped plate your motor mount is sitting on except on mine they are T shaped, and I used a bed of 5200 with lag screws to attach those to the glassed in supports. Glassing in your supports helps to spread the load and has much higher shear strength compared to just bedding the supports with adhesive. They have to be strong enough to handle the load cycling as the boat pitches and rolls.
