The pin at the bottom of my rudder is loose on my "new" Cape Dory 36. The pin is 1" diameter stainless about 5" long, and it's loose at the shoe, and at the rudder. Bottom of the pin sits in a cast bronze shoe attached to the keel, and top of the pin rides in a hole bored in the bottom of the fiberglass rudder. The traditional repair is to grind the shoe off the keel, put Delrin bushings in the shoe and the rudder, and reassemble.
Grinding out the shoe would involve DUST! Not sure about your part of the world, but around here boat yards, and private clubs, go nuts if they see dust flying these days. Is it possible to cut the pin with a sawzall, push the rudder off to the side just a little, bore the rudder hole a bit deeper, slide the pin/bushings into the rudder, then let the pin drop back into the shoe when the rudder is back on center? Maybe a dab of 4200 on the bottom of the pin?
Anyone done anything similar? Is there a way to fix this loose rudder without grinding out the shoe? Any thoughts or ideas on this?
Much Appreciated,
John
