I know traditional oil based varnishes stick to an epoxy base (West 105/207). 207 is the special clear hardener with UV blockers used as base coats for varnish. Done right, these varnish finishes look really great.
How about a two part polyurethane varnish, like Interlux Perfection Plus? Will it also stick to a West epoxy (105/207) base?
Any experiences? Advice?
John
Cape Dory 36 Tiara
I have used Perfection over West System epoxy but the West epoxy must be scuffed up sufficiently to give the surface some tooth for the Perfection to grasp. I found 100 or 120 grit seemed to do a pretty good job.
