Is there a table of recommended line size related to boat size?
I have a hunch that a bunch of my sheets and halyards have been swapped around on my boat as they wore out or convenient used line has been used to replace ones that have worn out. So, I don't feel that I can use what I have for reference when I go to replace them.
What would be your recommendations for main, jib, spinnaker sheets and halyards for a 30' boat? I'm guessing my Wanderer is close enough to Tritons and Alberg 30's to be in the same ballpark.
Recommended line sizes
svMira
- Boat Name: Mira
- markwesti
- Boat Name: Patricia A
- Boat Type: Westsail 28
Re: Recommended line sizes
For halyards , main , jib , I would say no bigger than 7/16 . I like Sta-Set New England , not to be confused with Sta-Set X . For sheets possibly but not necessarily 1/2 , because it's easier on the hands . For Spinnaker I'm thinking 3/8 halyard and sheets .
How did I do ?
How did I do ?
On boats the size of ours where nearly any line considered will be strong enough, for sheets I like to go as small in diameter as possible yet which feels comfortable in the hand. Keeping it small means keeping it light, so that there is as little weight as possible affecting sail trim in lighter air.
AFA halyards, I pick size based on the sheaves.
I'd say Marks dimensions are probably a good rule of thumb.
I like Sta-Set X for halyards because it is low stretch without fancy line pricing. It's about 1/2 the stretch of regular Sta-Set, which I prefer for sheets as it has a softer hand.
For Tritons, Alberg 30 and similar I use the following, all double braid polyester such as sta-set:
Halyards, spinn/code 0 sheets, reef lines, main sheet, vang - 3/8
Jib sheet - 7/16
Boom and whisker pole top lift, preventer - 5/16
Jib sheet - 7/16
