The last few times I was out on the boat, I noticed that it was pulling seriously to starboard when under power. I need to do a little more testing, but it was surprising. I got in the water and felt around the prop and rudder and as far as I can tell, all seems to be well. Any idea what I should be looking for? What would cause a strong pull turning the bow to the right?
Fresh water, 2 blade prop, 18hp Universal diesel, boat's only been in the water for almost a month.
Boat is pulling to starboard, especially under power
svMira
- Boat Name: Mira
Re: Boat is pulling to starboard, especially under power
Some prop walk is normal on many boats but if excessive it could be due to prop size, engine alignment, factory off-centerline shaft installation, etc. I'm not a motor guy but there is a good discussion on the issue at the link below:
https://www.cruisersforum.com/forums/f1 ... 35397.html
