Grinding to hole ratio
StephenHenson
- Boat Name: Nori
- Boat Type: Alberg 30
Now that I’ve removed some unnecessary thru hulls, I’m about to start grinding/prepping the holes for fiberglass. I’m getting conflicting opinions on “how far out from the hole” I should grind, and “do I need to dish out both sides(interior and exterior)” of the hole. Thoughts?
Re: Grinding to hole ratio
Grinding a very wide bevel outside increases the work and makes fairing more difficult. I grind a bevel about 4" back all around and don't bevel the inside. On the inside I add several layers of cloth about 12" square and that strengthens the outside patch so that you don't need to go to an extreme wide patch outside.
StephenHenson
- Boat Name: Nori
Thanks James! I’ll start grinding this week.
