Joe: So Many questions!
I'll have a stab at it and take some photos tomorrow, too.
This particular Vega is in very nice (stock-looking) condition. The only modification I can see right off the bat are the windows. Vegas came with a rubber moulding, holding in a tempered glass window. These are an
upgrade aluminum framed kit ... very nice.
OK, to the questions:
I'm curious about the details of the cockpit table:
The table is removeable and stows under the deck over the v-berth in two teak brackets ... it just slides in, right up to the anchor locker, and stays in place even in the roughest weather. It's far enough forward that it does not interfere with v-berth access.
There are fiddles all the way around on mine. Maybe this one was modified. One nice thing about the fiddles is the corners have been cut off, allowing crumbs to be easily swept to the floor ... no more messy crannies :-)
The table has two 'S' shaped legs that fit into two holes in the sole OR two holes in the cockpit floor, for outdoor dining! The holes are offset to the port side, and the fittings on the bottom of the table are also offset. These offsets, and the 'S' shaped legs, allow the table to be:
1. mostly over the port settee, leaving the companionway clear, but no room for seating on the port side.
2. partly over the port settee, still leaving the companionway navigable, yet allowing seating on the port side.
3. Centered on the companionway (for those large dinner parties), as shown in Joe's pictures, and ...
4. same as 2. but over the starboard settee.
The top is made of 9mm sapelle-veneered plywood with teak fiddles. It is surprisingly light weight yet strong.
It also looks like the galley extends over the starboard settee.
You're right: the starboard galley counter overhangs the settee, although the counter top matches the port side for length. This gives the starboard settee an extra 4 inches of length, making it about 6' 6" overall. The port settee is only about 6' 1" long. (I may be a little out with the numbers, but I'm 6' 3" and can sleep well on the starboard side, but have to scrunch up on the port side. The V-berths are also different in length from side to side, about the same as the main cabin, except the longer berth is on the port side ... probably for trim when sleeping four adults ... those clever Swedes didn't miss a trick!)
Everything I investigate on the boat has been well thought out and carefully engineered. I've been cleaning up the wiring lately, and was wondering why they used two fuse panels. (Yes, I know they're Volkswagen fuse boxes ... this is an economy boat, remember?) Anyway, the power from the navigation lights switch energizes the second fuse panel. Each bulb in the nav light system has it's own fuse, so if one shorts out you don't loose all you lights ... just the one.
I guess I'm beginning to sound like a Vega commercial, but I don't apologize. These are 'cheap' boats, but there was money and time spent on planning and engineering
before they went into full production, plus the quality of workmanship is very high.
Anyway, Joe, I'll take some pictures of the areas you asked about and post them tomorrow. Let me know of any other areas you'd like to see.
PS Both the main cabin and V-berth bunks sit parallel to the waterline.
