For the two years I have owned my boat I have been plagued by the necessity of replacing my shaft zincs every month or so. Since I scuba dive the boat every two weeks to keep her race-ready this is not a huge problem. However it is a pain in the butt, and the reason for the zincs being eaten away continues to elude me.
The boat has a very nice Xantrex Truecharge 40 charging system which features full galvanic isolation at all inputs and outputs. I've also installed a spiffy new galvanic isolator right at the point that the shore power enters the boat. I'm pretty handy with circut testers and digital multimeters and have checked every A/C circut, D/C circut, the galvanic isolator itself, the dock wiring, boats in close proximity to mine, and even stray current in the water at several points around my end of the marina. Also, I should point out that the shorepower A/C system and the boats D/C system do not share a common ground. A/C uses the shore power ground and D/C is grounded through the engine block.
I'm posting about this problem now because I saw something when I had the boat hauled for the winter this past Wednesday. The paint on the lead keel / centerboard trunk was coming off in an odd pattern. I used a good lead metal primer before the bottom paint went on too. The pattern reminded me of galvanic patterns I have seen on badly corroded props in the boat yard.
Here's a picture...
Is it possible that a combination of aluminum mast step, aluminum mast, aluminum spacers on the keel bolts, stainless steel keel bolts, washers, and nuts, lead keel, and saltwater in the bilge could be generating current capable of stripping my shaft zincs? The keel/mast/rigging complex is not bonded to the engine block and is therefore separate from the D/C system. The connection would have to take place through the salt water between the shaft and keel.
It never occured to me to test for current generation in the keel so it is one thing I haven't checked for. Has anybody ever heard of something like this happening? Any other ideas would be welcome too.
George Jones
C&C 40 "Delphinus"
Wavelength 24 "Poco Loco"
