jhenson wrote:The towing eye seems awfully small on mine and very close to the water line. Do you tow yours from there, or is there some kind of different harness arrangement?
I tow from the stock eye. It is small, but the metal is plenty strong for its purpose. Padeyes like this are deceptively strong.
I find the eye to be too small in section, though, and therefore "sharp" to line, so I run the line through some hose chafe gear that prevents the eye from damaging the line.
The eye is located where it is because that's the optimum towing connection. Any higher and the bow might tend to plow and therefore cause the dinghy to yaw. The stock location seems to work excellently. I find the boat tows very nicely.
I need to add a fender on the bow like yours has. Occasionally at anchor, the dink will ride up (often thanks to an ignorant powerboater's wake) and want to bang the taffrail on the boat. The topsides are so high on the FK, and the stern on the Triton so low, that it places the stem squarely on the taffrail. Ouch!
