holding tank vent line
I'll be installing a holding tank up forward under the v-berths on our Challenger and wonder about the vent line-
All the thru hulls lead to the transom (or below the waterline up forward if they can be submerged), and I definately don't want any thing on the hull up forward. There are two dorades where I could maybe hide a vent gooseneck. Would it be nuts (stinky) to run the line back through the cabin to the lazarette- maybe with multiple filters?
I've read about sch 40 pvc here but don't know how practical it would be to run it that far.
Thanks for any input.
dmairspotter
- Boat Name: Wind Horse
- Boat Type: 1974 Dufour 27
Duncan
- Boat Name: Coquine
- Boat Type: Cape Dory 27
Re: holding tank vent line
Definitely nuts - that setup will restrict airflow and make things worse, not better. Oxygen is our friend, since it kills the stinkers (anaerobic bacteria). (That's why they have aeration ponds at sewage treatment plants).JSmith wrote:Would it be nuts (stinky) to run the line back through the cabin to the lazarette- maybe with multiple filters?
So, it sounds perverse, but the bigger the vents, the less it will smell. Nice large vents as straight as possible to the anchor locker and the dorades sound almost ideal to promote airflow.
Cape Dory 10 & 27
dmairspotter
Should have stipulated that on my boat the anchor well is isolated from the cabin and has its own dedicate drain.
On my last boat, seems to me there was a little fitting that went through the hull up near the deck join
Something like this, though I think mine was smaller
http://www.westmarine.com/webapp/wcs/st ... rtial/75/0
Summersdawn
Consider adding 2 vent lines, one to each side. That way you get cross-ventilation.
The more air flow the better, big hoses help as well.Oxygen is our friend, since it kills the stinkers (anaerobic bacteria). (That's why they have aeration ponds at sewage treatment plants).
Rick
Summer's Dawn
24 San Juan #380
Summer's Dawn
24 San Juan #380
I'll only have one tank but the anchor locker is also vented to the cabin with multiple holes in a plywood cover just fwd of the v-berths. It might make sense to replace that with a solid one which would cut down on moisture below as well as give me a place to vent to. Going to a dorade wouldn't really work- the air goes from there directly below (and if I turned it to face aft to "suck" it would be turned back at some point by some one).
Mark.Wilme
Presuming your Challenger is an Alden with lots of nice obstructive woodwork, like our NE 38... Our holding tank vent is forward of amidships, piped into to the vented loop concealed in the head casework. Easy to plumb, easy-ish to access.
Don't do it! And don't lead it forward or into a dorade. Since we are more likely to not be going dead downwind, I will be moving mine aft, waaay aft! More often than not, one gets an unpleasant waft when sitting in the cockpit while the other has pumped the head.
I don't think you get much 'ventilation' through any 5/8" dia hose, what you get is no 'inflation' of your tank when decomposition and off-gassing occurrs, and when you pump more waste into it. I think the only criteria is to not leave the hose with a droop causing a trap to hold water (from whatever source). Our previous boat's vent was on the transom, something like 15' aft of the tank, hose, worked fine.
Boats are not normally plumbed with ordinary PVC, I understand because of vibration and breaking. I've used CPVC on my new water system, so we'll see. Very tempting to use such pipe since it will tend to droop less and look neater, as well as be more likely to go where it's pushed when fishing behind casework.
As long as PVC is properly supported-- especially over the long runs you are talking about, it should work OK. But that is a lot of pipe!
I agree that the vent should not be in the dorades. It STINKS if your head is close to capacity -- especially in the middle of the summer-- no matter how well vented! I have a 1" dia. vent on mine with a run of 5 feet and two 120 deg bends, vented amidships just below the toe rail. I couldn't get it any better than this and it still stinks once in a while when someone flushes.
Summersdawn
