My boat has the original A-4, and the intake is/was on the port side of the bilge, near the front end of the engine compartment. You can see the backing block near the bottom of this photo:
The hose actually crossed over to the starboard side to supply the engine, getting in the way of my already meager access to the deep bilge. Between that and the Sumlog cable, reaching in there was a real pain (and I can't remove my engine every time I want to clean). Here you can see the intake ball valve, which has a green handle, and the hose crossing over the front of the deep bilge:
It would be nice not to have it do that, but I'm not sure it would work to bring it in on the starboard side because it would have to make a sharp turn. How do the engine intakes on other boats come in? Is the intake on an A-4 an oddball or do most engines have it in roughly the same location (on the engine)?
Also, the through-hull I removed was 1/2", but I plan to increase it to 3/4" -- that's more-or-less standard, right?
Thanks ahead,
