Backing blocks for seacocks
cdawgs65
- Boat Name: Ring
- Boat Type: Pearson Triton 559
Is there a standard thickness for backing blocks, if so what is it, I have some pieces of mahogony plywood 3/4" that I want to use, it's for my Pearson Triton 559, thanks
I don't think there's a "standard" thickness. I used 3/4 ply for my seacock backing plates. Some materials (such as manufactured fiberglass panels) can be thinner than others.
cdawgs65
- Boat Name: Ring
Backing blocks,
Thanks for the reply, I kinda figured but just wanted to be reassured, like your website,
JonnyBoats
[Edit: Rachel beat me to it....]
NO! Search for a thread a few months ago about starboard to get the skinny.
1. nothing sticks well to starboard (i.e. caulk) especially epoxy or polyester/vinylester.
2. the rate of expansion and contraction of the pastic will invite leaks
Good wood (marine ply, teak, etc.) can be used if well coated with epoxy. The epoxy seals out the moisture which could cause wood to expand,
FRP (see Rachel's Downsizing a TH thread: ) works well too.http://triton381.com/forum/viewtopic.php?t=2256
Maine Sail
I used fiberglass
I simply laminated a 5/8 inch thick piece of fiberglass on a waxed piece of glass and then cut holes with my hole saw and glassed them to the hull.
Glassing my backing plates to the hull!
Nice and Solid!
Ready to be installed with Sikaflex!
Nice and Solid!
