I'm attempting to secure hardware to the deck for the leading edge of my dodger. I have overdrilled and filled the holes with epoxy twice now and both times I've tapped the holes for the 6-32 machine screws there's been hardly any bite to the epoxy; the screws strip it right out with only moderate pressure. I know this has been done routinely by some of you here. What am I missing?
Is it best to use straight epoxy or a mixture? If a mixture, what additive is recommended?
Thanks!
Overdrill, fill, and tap
David VanDenburgh
- Boat Name: Ariel
- Boat Type: Cape Dory 36
David VanDenburgh
- Boat Name: Ariel
Thanks, Tim
Pardon my ignorance, but is it correct that West System's colloidal silica is the same as cabosil?
David VanDenburgh
- Boat Name: Ariel
If a whole week is required to gain full hardness, then that might be the source of my problem. I only let the epoxy cure for a couple of days - approx. 48 hours. I did park an oil-filled electric heater under the part (the sea hood) on low heat to facilitate curing, though. I'll try it again and allow more time.David wrote:I use West System high density 404 filler and let it cure for about a week to gain full hardness before taping the holes. They are impossible to strip out when done correctly. Are you using the right size bit and tap?
By the way, yes, I'm using the right size bit and tap.
Thanks for the response.
Re: Thanks, Tim
Yes. Cabosil=colloidal silica. It's also variably known as aerosil or fumed silica. All the same thing.David VanDenburgh wrote:Pardon my ignorance, but is it correct that West System's colloidal silica is the same as cabosil?
