Bow roller for a 22 lb Bruce.
s/v Groovy
I am looking for a Bow roller for a 22 lb Bruce anchor, well really a Lewmar Claw. I tried a Windline BRM-4 and it didn't fit. the Lewmar roller for up to a 44lb it is very loose, and would shift and rattle all day. I want to test a Kingston Bruce 25 roller, but would have to mail order is to just try it...
Is there a good roller for my Lewmar Claw, should I get a different Bruce style anchor? get the Kingston 'Bruce 25' roller? or is there a better roller?
Gregg
Pearson Renegade #145
Bruce (and the similar Claw) anchors have unique storage needs thanks to their designs. The Kingston Bruce 25 roller you mentioned looks like it ought to work, but I don't specifically have experience with that one.
The Windline BRM-3 or BRM-4, both of which are made specifically for a Bruce/Claw anchor, would work. These rollers are necessarily a bit large and bulky, unfortunately (and expensive), but fit the Bruces quite well.
I think the BRM-4, which fits up to 44 lb. Bruce anchors, would be kind of big for your 22; I have one of these for a 33 lb. and it fits well, but it's a large roller to be sure. The BRM-3 is supposedly good for only up to the Bruce 16, but might be worth a check to see if it works for you.
s/v Groovy
update:
I finally found a Genuine Bruce 22 for sale and it fits the BRM-4 perfectly (The Lewmar Claw did not). With the genuine 22# Bruce this bow roller holds it securely with almost no movement at all.
I also found a Windline BRM-4 on clearance at West Marine for $141.00 (since the only anchor it fits isn't being made anymore).
This roller is quite large, agreed, but then again, so is the 22# Bruce on a Renegade. Everything should fit by moving the starboard bow chock back. The leading edge will stand quite proud, but it will be within the vertical of my pulpit, and thus not extend my LOA (my marina charges me for every inch)...
Gregg
I've been avoiding adding a roller to my Renegade for a couple years. I think they're ugly. But this past 9 day cruise has begun to persuade me into thinking I want one. Hurry up and resolve this Greg, and post some pictures so I don't have to figure this out myself! :)
s/v Groovy
The battle ram, I mean bow roller is installed. I too agree that it is a bit ugly, but I'm really looking forward to sleeping better when on the hook for a night. The 22# Bruce replaced a 13# Danforth that came with the boat.
I cut one Teak piece to bring mounting up to the height of the toerail, notched for the pulpit base. A second thinner piece of teak was cut to raise the height a bit more, however, a small notch was still needed to be ground in the outside of the bow roller to clear the pulpit riser tube. Holes were drilled in the deck and epoxied to protect the core. once cured (overnight) the Life Caulk sealant was used to through bolt the roller. I also mounted a Lewmar anchor stop as a secondary safety from accidental anchor drops.
The starboard chock has not been reinstalled yet. I imagine I want it as far forward and possible now, but I wanted to ask if this is correct before I drilled, also, is there a reason to move the port chock back to match the starboards now location other than symmetry?
Try to ignore the epoxy repairs the have not been gelcoted on the hull edges. When I was in the boatyard last month I chased out quite a few voids and marginal repairs with a Dremel These were then filled with epoxy, thickened with chopped glass and cabosil. These were sanded and faired, but I didn't think I had the right gelcote to complete the process. I'll start a new thread about spraying gelcote, and my questions.
Gregg
Gregg,
I really like the installation!
In particular... You've got bow lights exactly where I'm wanting to put mine. (Grin)
LazyGuy
- Boat Name: Paper Moon
Greg,
Nice install. I have the same installation for my Bruce 33 and while I hate the look, I hate the look of the galvanized gopher teeth swinging in the breeze even more. Especially after I saw a good friend with a Tartan 33 rip a brand new, first time out of the turtle spinnaker on the Danforth pulpit mounting thingies. He put two slices from about 2/3 the way up, to within a foot of the foot of the sail.
Dennis
Dennis
