Sooooo
Dry fitting the balsa:
And gooping in:
Cloth is next. Then clean the other side, then balsa and cloth the other side. A few layers on the "keel". Also a corner on the hull to deck joint on the inside, as well as some reinforcement where the chainplates go.
The good news is that the other hull is not half as bad. It has dried up, and there is maybe 12-15 feet total on both sides that need re-doing......
