1. New tracks are about a foot shorter. Which end should lose the last foot, forward or aft? (Yankee cut genoa and running backs, two sets of blocks on each track). One rigger I spoke to thought I should honor the aft end, sacrifice the forward end. Would rather do the opposite as the aft-most bolts are harder to reach down below.
2. Since I'm going through the wood caprail, then the hull deck joint, should I drill and tap? Countersink the wood?
3. What do you suggest I use for bedding the fasteners, or the track for that matter. Boatlife seems like it might only stay viable for a few years?
4. Would you start bolting on the forward end or aft.
In the picture below, you'll see the strbd caprail after doweling. Note the little pad eye on deck, that is in the cockpit, to the right of that, on the bulwarks, you can see one of the three holes where the winch bracket is mounted. I point all this out so you can see how aft the original track went. I've never had the car that far aft...
Lots of questions, sorry, I'd really like to get this right. Anything I'm not asking and should consider?
