I have a question relating to some wood parts I need to rebuild on my 1980 GRP Hess cutter. I'm working on sourcing materials for my Sampson posts and my cover boards.
This photo has both parts in it. The cover boards are along the sides of the deck covering up the hull/deck joint, under the bulwarks. Sampson posts are obvious...
I've been looking at using Sapele or Khaya. Sapele is easier to come by but I have not found much on the durability of Sapele in marine applications. I've found a few places online that say Sapele is NOT for marine applications while others say that it is but gives no reason. Then I find places that sell Sapele plywood for marine applications. It's all so confusing sometimes. I really like Sapele's color and it seems much heavier (stronger) than other "African mahoganies," but what do I know?!
The cover boards will need to be 4/4 12"wide by 12' long so I have room to make the curves of the deck. While the sampson posts will be 2 laminated 8/4 boards at approx. 55" long. I made an order of Sapele but later was informed that they didn't have any vertical grain lumber to supply so I would have to wait. Now I'm having second thoughts about sapele and wanted some input from those who know. Would Khaya be a better choice?
Bryon
