Painting the Hull
rickal4884
Painting the Hull
When repainting the hull do you paint the entire hull with primer or do you leave the area below the bootstripe for bottom paint only?
Re: Painting the Hull
Bottom paint only.
unless you count "barrier coat" as primer.
I'll get my coat....
There is no reason to prime the bottom, but it is usually good to lap paints vs. mask to a mechanical seam. I suggest the primer go below the waterline a little to be lapped by the bottom paint to a masked seam with the topside or boot top. If you use barrier coat, the primer should lap it a little vs a masked seam.
The Froon
- Boat Type: Westsail 32
as such...Interlux Epoxy Prime-Kote on the topsides, with bottom faired and ready for bottom paint (or barrier coat - no frowns out there please)...
"My best days are ahead of me..."
http://www.seasprite217.blogspot.com
http://www.westsailstory.blogspot.com
