I've left all this here for historical accuracy! This list is obsolete, some of it complete some of it not, all updates will be at the bottom!
I've finally got round to starting the blog for my new project, if any of you have read my old one you'll know that I now have a new boat that doesn't need half as much work!
This is my attempt to document the process, no doubt I'll need to ask for help and advice along the way, but thats the spirit of a forum :).
First off the planning! Its by no means a finished plan, but it gives me a direction for the moment and highlights what I need to be planning next.
Sadler 25 "Polaris"
Overview
The plan is to refit the boat in a manner that will allow me to live aboard in reasonable comfort, obviously being a 25footer there are limitations on this, but I think I should be able to manage a small well insulated cool box, some form of heating for when I'm in temperate climates, also to help dry out boat if its got soaked inside from bad weather etc. And preferably hot and cold running water, I know on this size boat its rather overkill, but if I'm living on board than I want some comfort! I'll use a hand pump when on passage.
I shall also be beefing up the various fittings etc for taking the boat offshore, I would like to do a transatlantic and possibly more, so a good well prepared boat is essential.
Areas that still require planning:
- Electrical System Done!
- Deck Layout
- Heating/Water Systems Done!
Work to be completed:
Hull
- Clean + Polish
- Fill and Repair Gelcoat
- Name + Stripe Vinyls
- Complete Deck Layout Plan
- Re-Bed Existing Deckhardware (Prevent Leaks)
- Re-Seal Windows and Forehatch
- Renew Guard Wire Ropes
- Renew Non-Skid
- Remove Old Engine Done!
- Red Oxide Mounts Done!
- Fit New Engine Done!
- Change Fuel Tank Done!
- Change Fuel Lines Done!
- Change Water Inlet Hose Done!
- Change Water Inlet Seacock
- Replace All Lines
- Replace All Blocks
- Give it a thorough examination
- Fit LED Tri-Colour
- Fit Steaming Light
- Renew Varnish
- Make Interior Plan
- Plan Water/Heating System
- Un-stick all the blakes seacocks
- Remove old water tank
- Measure up for Windvane
- Remove all old electrics Done!
- Re-site batteries
- Design Electrical System Done!
Heating
Heating is going to be a blown air system from Eberspacher, it does draw a large amount of current initially, but once running is pretty economical on both power and fuel.
Eventually when I can (one day!) afford one, I'd like to switch to something like this which is VERY low power consumption! :)
http://www.kuranda.co.uk/new-wallas-heaters.html
