Need a surface thermometer
tartan30cirrus
Topside Painter
Post by tartan30cirrus »
Anyone know where I could find a surface thermometer that willl measure up from the 30s. I want to use it to see if my boat is warm enough for eopxy/paint/etc. work. I have an air thermometer.
Clint Chase
Tartan 30 Cirrus #388
Clinton B. Chase
Tartan 30 #388 Cirrus
Portland, Maine
Dan
Post by Dan »
I use one of these. I see they are $79.00. There are two models, one with a laser and one without. The only reason for the laser is to play with the cat. It serves no purpose. You will need to get the temp gun very close to what you are measuring. I see people use them at 6 and 8 feet distance and they are not accurate at all at that distance. I place it right against the object I am measuring. They also don't like real shiny surfaces.
http://www.raytek-northamerica.com/cat. ... rthAmerica
