Cleaning Bronze Jib Hanks
hriehl1
- Boat Name: s/v Mooney Hahn
Winter Projects continue. I have 3 hank-on foresails all of whose bronze hanks have some blue-green surface corrosion. I'd like to clean them but some years ago on my Daysailer I cleaned them (I think with WD40 or similar) and ended up with clean hanks and a stained jib.
Does anybody have techniques (materials, methods, whatever) for this task that'll minimize the likelihood of stains on the sails?
Thanks Hank
Thanks Hank
danielguiod
- Boat Name: HOKAHEY
Re: Cleaning Bronze Jib Hanks
I've used muriatic acid to clean hanks, but they were off the sails. After they need to be rinsed in a baking soda solution to neutralize the acid and then rinsed thoroughly with water. You must use eye and skin protection, and be in a well ventilated area!!! It is a worthwhile skill to know how to sew on hanks.
plain old lemon juice will clean the green off. Does a great job. I clean all my bronze using it. Can't say if it'll strain the sail- most likely the green would.
triton318
- Boat Name: Dove
I thought that the green-blue patina bronze develops is good for the bronze; sort of protects it. Why get them all clean and shiny when they're just going to return to the state they're in now?
Jay
Dove, Pearson Triton #318
Hayes, VA
Hayes, VA
Whether you clean the bronze or not, to avoid staining the sail, use a dry film lubricant such as McLube SailKote in lieu of WD-40
LOL- good point. It's really a form of oxidation, which is what rust is. I've begun just washing the bronze with a soap/water solution, and letting it be.triton318 wrote:I thought that the green-blue patina bronze develops is good for the bronze; sort of protects it. Why get them all clean and shiny when they're just going to return to the state they're in now?
Green is beautiful!
Tallystick
- Boat Name: Nostalgia
Copper oxidation. like aluminum is protective because the density of the oxide is similar or higher than the metal, unlike iron rust which has a lower density so it expands and flakes off exposing fresh metal to be rusted.
Yep- as I said- it's really a form of oxidation. and washing it leaves a nice brownish patina, which I really like the looks of. But sometimes old bronze is so corroded it looks terrible. And the pistons get clogged up on piston hanks.
Tallystick
I haven't messed with any of the stuck hank pistons on my sails yet. Do you suggest lemon juice to remove the oxide clogging the pistons, or just brute force and lube?
I'd keep them wet with the lemon juice for a bit, then keep gently working them. I found two sails in a dumpster at Point Lookout Marina when we were there, all rigged with bronze hanks, many of them corroded to the point of immobility . Cut them off the sails and soaked them in a jar with lemon oil for several hours and got everyone of them loose. 10 of them are now on my genoa.
seasailor55
- Boat Type: Cape Dory 22 Pearson Ensign
I have the same problem with the bronze jib hanks on a Cape Dory 22 and a 1965 Pearson Ensign, both undergoing restoration for a youth sailing program. Both have bronze hardware (original winches, genoa track, etc.) in various states of oxidation. I'll try the lemon juice (at least it smells good!) and see what happens. Thanks for the tip.
Hulukupu
- Boat Name: Mahana
Even on my grand-dad's Dark Harbor 17, it seemed like finger-force would work for hanks to free them. Once they are moving, pull and twist repeatedly. Nobody mentioned a small brass brush, but that works well if they are initially caked with oxidate. The powder from the oxidate seems to lubricate the same way Sailkote does. I'd use Sailkote over lemon juice, but try nothing but fingers (and patience) first.
