After 30+ years, and several prior owners, the original electrical panel in my Cape Dory 28 was ripe for replacement. So, I bought a mini battery selector switch and a prefabricated electrical distribution panel from Blue Seas Systems, set them in teak veneer plywood to cover the old hole, and wired it up. All works well.
As often is the case, this solution generated more questions:
1) If I run the motor with the battery selector on both (1+2), am I really charging both batteries? Or is my older (weaker?) AGM batter just sucking power out of the newer AGM battery?
2) Can the 70amp alternator (w/built in voltage regulator) on my little Beta 14 pump out enough amps to actually charge two group 31 AGM batteries at the same time without burning up?
I'm not much of an electrical wizard, so any and all ideas are greatly appreciated.
John
CD28 #241
Tantalus
