My automatic bilge pump has always been one of those self contained units that sits in the bilge.
It sort of crapped out this year so I'd like to replace it. My manual backup is a Whale mounted in the cockpit, well away and higher than the bilge. It works really well. My bilge is pretty cramped, so moving the pump to a remote location has some attraction. Any words of advice/recommendations.
Thanks in advance.
Bilge pump NOT in Bilge?
dmairspotter
- Boat Name: Wind Horse
- Boat Type: 1974 Dufour 27
Re: Bilge pump NOT in Bilge?
There are many options, but you first need to decide the purpose of the new pump. Is it to remove small amounts of remaining water once the manual pump has removed the majority? If so a small pump sitting as low as possible in the bilge would work. If it is to function as an emergency pump to move large quantities, then something else may be appropriate.
Paulus
- Boat Name: Guillemot
- Boat Type: Mariner Ketch
The whale is self priming - any centrifugal pump will need to be sitting in the water...
dmairspotter
Purpose is to be the automatic pump just for (hopefully) minor amounts of water that collect in the bilge. I found some pumps that can suction lift a few feet but they are quite expensive compared to the submersible ones, so maybe I'll just replace with a like pump.
Bear in mind that a submersible, centrifugal pump won't ever get the bilge DRY. The water in the hose will always run back, and it's not recommended to put a check valve in. A suction pump will pump it totally dry since the pump itself sits up out of the bilge.
Not a major thing, but something to be aware of.
Personally, I have a decent sized centrifugal, and a Whale Gusher 10 back up.
