Reconstucting the Chainplate Knee and shelf from the dinette area on our Bristol 26
OverTheReef
Bottom Sanding Grunt
Boat Name: Affinity
Boat Type: Bristol 26
Post by OverTheReef »
I put this project on my website, but thought I'd post it here to possibly get some expert opinions on the project. I did this last summer, and will probably start the starboard side this year. Let me know if you think I should do anything differently.
One of the first things we wanted to do was get rid of the carpet and felt lining on the inside of the cabin. There was a 1970’s yellow-brown felt adhered to the cabin walls, and pieces of blue carpet were glued on top of the felt at some later time. Both were moldy and darkened the cabin quite a bit. Our plan was to remove this fabric, then clean and paint the walls white to match the cabin roof liner.
After removing the carpet and fiberglass covers, I realized we had a bit more work on our hands than we planned on. There was a gap between the chainplate knees and the deck of the boat. The upward pull of the rigging was causing the knee to separate from the inside of the cabin, as it was only attached to the side of the hull.
The chainplate was also leaking and had rotted the plywood shelf under it. I decided to remove all of this and replace the knee. I wanted to integrate the new knee into both the new shelf and the bottom of the deck, making it much stronger.
The benefit to this poorly installed structure was that it was pretty easy to remove. A hammer and a construction chisel were all I needed to remove most of the fiberglass, which minimized the grinding and sanding I’d have to do later.
Doing this project while the boat was on it’s mooring was challenging–I must have made some people wonder as I was hauling tools and rotten plywood back and forth to the public boat launch where my truck was.
I used cardboard to make new templates for the replacement pieces. Once I made the templates, I could cut the pieces out of plywood at home.
I decided to cut a section of the liner out of the cabin, and butt the new knee against the bottom of the deck. I would bring the knee down to the shelf, making the shelf a part of the support structure.
I also decided to leave the section under the shelf open as well. The old board under the shelf wasn’t doing much other than closing off space and making our sailboat feel a little bit smaller.
The cardboard templates were easy to make and folded up well for transport, but I might try poster board next time. You can see in the picture that the floppiness of the folded up cardboard made it a bit difficult to make an accurate template.
Once I got back to the boat, I had to make a few cuts to the plywood with my multitool and cordless angle grinder with a flap disc on it. It fit reasonably well after that. I mixed up a batch of slightly thickened epoxy, and sandwiched the two boards I cut for the chainplate knee together. Next, I brushed an epoxy layer on to the mating surfaces on the boat and the plywood, then placed the shelf and chainplate knee into position. I supported it with some boards and tools to keep it in place.
To make a fillet, I used Mas Epoxy’s Gluzilla. It comes in a caulking tube, and mixes in a special nozzle that has an internal corkscrew-shaped mixer in it. It’s more expensive than mixing your own batch, but it’s very convenient, less messy, and nicer looking when finished. I also end up with less waste, as the epoxy is only mixed as it’s used, so I can just throw out the tip when I’m done and keep the rest of the tube for the next project. You can see the difference in texture where I used my own mix of epoxy and filleting blend (the dark brown area).
I used my router to cut a groove in the outer part of the shelf, and, after coating it with unthickened epoxy, attached it to the plywood shelf with screws. I also used Gluzilla to make the fillet for that piece.
I'm hoping that this design will be much stronger than the original. The shelf is now a structural part of the boat, and the outer shelf ties in with the chainplate knee, which is bonded on all 4 sides–unlike the original design, which was bonded on only one side.
The next time I was at the boat, I applied a few layers of West System 4″ biaxial tape to tab the shelf and chainplate knee into the hull. I then put a skim coat of epoxy resin thickened with West System fairing compound.
The old chainplate didn’t look terrible, but it had some pitting where it passes through the deck, so I bought a piece of 316 stainless flat bar that was the same width but slightly thicker than the old chainplate. The piece of flat bar is enough to make new chainplates for all four lower shrouds, and cost about half as much as buying one pre-made chainplate.
I don’t think I took any pictures of that process, but I basically copied the pattern of the old chainplate, then used my sawzall and bench grinder to shape the new piece. I went slow while grinding and cutting to avoid heating the plate too much, which can change the hardness of the metal and create internal stresses and future cracks.
After making a rough shape, I used a combination of the flap wheel on my angle grinder and wet sanding to polish the new chainplate. I then trimmed the top part off the old chainplate and used it as a backing plate for the bolts that secure it to the chainplate knee.
I drilled oversized mounting holes in the chainplate knee, then filled the holes with thickened epoxy and redrilled them to the proper size. It should keep any water that might leak in from saturating the plywood chainplate knee.
I primered the area with TotalBoat’s TotalProtect epoxy barrier coat. I wanted a durable coating that would keep water out and prevent as many future rot and moisture issues as I can. After that, I applied Sherwin Williams’ Emerald urethane enamel in a beige color I had mixed to match the cabin liner.
I left the bulkhead a bit unfinished, that will be the next part of the project. I’ll have to remove that chainplate and reinforce the area where the bolts pass through the bulkhead. Whoever reinstalled it didn’t use large enough washers on the bolts, and the boltheads are compressing the wood.
Joe
1970 Bristol (Sailstar) 26
Boat Name: Ella Marie
Boat Type: Bristol 27
Re: Reconstucting the Chainplate Knee and shelf from the dinette area on our Bristol 26
Post by Lloyd »
OverTheReef
Good looking project. I like the ‘better than new’. How hard was it to drill the holes in the new chain plates?
OverTheReef
Boat Name: Affinity
It wasn't too hard to drill the chainplates. I drilled pilot holes, and opened them up with a unibit and lots of cutting oil
Joe
Thanks for sharing that. I'm sure it will be helpful for others tackling a similar job. I'm dealing with the same issues now on a Cheoy Lee Clipper 33. Looks like the job went well so not much I can add on doing it differently. Interesting that you cut the stainless with a sawzall instead of chop saw or angle grinder with cutting disc as I do because you wanted to avoid heat. I don't see that as an issue because the heat affected zone is close to the two ends and nowhere near the holes (I'm assuming you didn't try to do a lengthwise cut when you can order it the correct width). I mention it because I think I'd dull many sawzall blades trying to get them cut judging by how fast they dull on fiberglass cuts. It worked for you so doesn't matter. I haven't tried the Total Protect epoxy barrier. I often use Interprotect 2000e for hidden lockers and leave it without paint on top. You had visible areas with the need to paint a topcoat over it. I can get either one for about the same price from my supplier, although the 2000e is 30% less if I buy the 3 gal kit. I wonder if you've used both and can compare them. I like the 2000e because it goes on easy and not too rough or runs when using a roller, dries quick, two coats covers well, and the finish is matte instead of glossy. I'd like an even smoother finish so would try the Total Protect if it was better.
smcgrath67
Boat Name: Leah Mae
Boat Type: C&C Corvette
Post by smcgrath67 »
Thanks for posting this, as I'm working on the same project myself. Yours looks great.
OverTheReef
Boat Name: Affinity
I just remembered why I used a sawzall to cut the stainless chainplate. I had ran out of cutting wheels for my angle grinder, so I used the sawzall instead.
As for the totalboat barrier coat, I was happy with it. I don't have any experience with the interlux, so I can't compare it, but I'd definitely use the totalboat product again. For me, I think it was slightly cheaper than the interlux at the time
Joe
