Thanks for the reply. My upper coachroof does have a core. It seems strange to me that there would be so many variances in these boats over such a short period of time.The topmost coachroof has no core.
It's almost as if the people actually building the boats on the shop floor had little or no direction, and made do with what was at hand--materials, design, engineering...jhenson wrote:It seems strange to me that there would be so many variances in these boats over such a short period of time.
hmmmmm. I can't seem to find my receipt from the core order, so I can't say for certain how many sheets I had when I started, but based on the space left in the box, I'd guess it at 6 2x4 sheets.jhenson wrote: Can you recommend the quantity of 2' X 4' balsa sheets one would need to do the lower decks. For that matter, any other comments on supply quantities for this job would also be appreciated.
Joe,jhenson wrote:how many laminations were required to build it to the deck skin thickness?
Wow, that makes me shudder thinking about grinding interior paint again.I spent some time scraping and sanding bad old paint on the interior of the boat yesterday
These look like the ones I saw in Hamilton Marine that have rubber balls in them to keep water from flowing back up through the drain. From looking at your picture, it looks like you could remove the balls if you wanted. Am I correct?Here are the cockpit drains of which I guess you are familiar
You are more or less correct. ABYC H-4.4.9.1 states that...JonnyBoats wrote:If I am not mistaken, the test for adequate cockpit drains is that if you cover them and fill the cockpit with water, hen uncover them the cockpit should drain in 90 seconds or less.
There is also two formulae, one of which is below:ABYC H-4.4.9.1 wrote:When filled with water to the fixed sill height and with weathertight hatches sealed to the height of the sill, 75% of the cockpit water volume shall drain in 90 seconds. There shall be no leakage to the interior during the test.
Don't do it. They won't drain. I speak from experience.jhenson wrote:I sort of hate to cross the hoses since I don't see how well they would drain when the boat is heeled, but if you think they would drain OK that would certainly be the simplest solution.
Bear in mind that this material is a close cousin to the bullet-resistant panels used around teller's windows at banks and such...Tim wrote: I used the manufactured laminate (1/2" thickness) for backing plates on the Daysailor. It is nice stuff, but a word of warning: it was extremely hard, and very tough on the tools.
Nope. I know that the 1-1/2" drains (two) will be more than sufficient for rainwater and normal amounts of spray. The cockpit is obviously too large to meet calculations intended for offshore boats; it's an inshore boat, to be sure.JonnyBoats wrote:Out of curiosity Tim, did you do the calculations for your Daysailor project to see if it complies with ABYC H-4.4.9.1?
Very true. I forgot you (Joe) had the engine out. Picking the best spot between the bulkhead, transmission, and in my case, the aftermarket engine exhaust system, becomes a bit of a ballet. I think the backing blocks for my seacocks sit about and inch or two aft of the bulkhead. If I can remember I will take some pictures tomorrow.I highly recommend you know where your engine parts will end up before you place your seacocks
Don't say that.If you own the boat for any length of time, you will have to replace the hoses
How much water could two 1.5 inch drains be expected to pass in 90 seconds?I know that the 1-1/2" drains (two) will be more than sufficient for rainwater and normal amounts of spray.
There is another formula for that calculation:JonnyBoats wrote:To ask a related question, if one computes the volume of their cockpit (and thus the number of gallons it can hold), how does one compute the drains required to pass 75 percent of that volume in 90 seconds?
This is really the reason I thought I would try a something different than the bronze drains with the tapered edges. The problem, as I understand from reading about it, is that when the drains and seacocks are fixed, one cannot bend the marine reinforced hose onto them because of the inadequate space between the two. What really seems to be needed is to have the ability to remove one of the castings, and obviously the seacock, with the boat in the water, is not a good choice. One thought was to have the bronze tapered drains (like on Glissando) epoxied into a round cutout that was screwed into a flush recess in the deck. The Perko units would be similar in the principal.If you own the boat for any length of time, you will have to replace the hoses, so it's best if you can come up with a solution that allows you to do that.
Technically, I already have! hehe ;<)Figment wrote:At this rate, Tim's going to have the Daysailor floating...
