Good evening!
I am looking for thermostatic mixing valve that tempers the 160+ degree water (from using the engine to heat the water) in the hot water heater so that my we don't get burned by it when we start cruising.
Some of the H20 Heaters have them in place from the factory. Does anyone make one that you can retrofit?
Water heater is basically brand new so I really don't want to replace it.
Thanks in advance!
Ric
Retrofit Thermostatic mixer for Hot Water tank
Ric in Richmond
- Boat Name: Andiamo
- Boat Type: Alberg 35
