Anchor lantern
windrose
Anchor lantern
Post by windrose »
My Pop gave me a nice anchor lantern with a fresnal lens.... but the dang thing wicks fuel out of it constantly.... any way to stop this. I don't like having it on the boat because it makes such a mess.
windrose
Post by windrose »
Is this just too dumb of a question, or is the answer so obvious everybody knows it-- except me.....
catamount
Boat Name: GREYHAWK
Boat Type: Peterson 34
Post by catamount »
OK, do you roll the wick back down when not in use?
I was going to answer, "replace it with a Davis mega light", but didn't want to seem like a wiseguy...
Not having any oil lamps of any sort on board, I have no valid answer to your question. They've never excited me, so I've never had them.
Eric
Almost a Finish Carpenter
Boat Name: Sophia
Post by Eric »
Another idea (nothing is too obvious): check for leaks...
Harry James
Post by Harry James »
I was raised with kerosene lanterns, we didn't have electricity. By wicking fuel do you mean that the fuel level slowly goes down, or fuel actual comes out?
A kerosene lamp will slowly evaporate kerosene through the wick, but it shouldn't be noticable. Lowering the wick will slow this process up. If it is damp at all with fuel you got a leaker and a fire hazard.
I got more comments on kerosene if anybody is interested.
windrose
Post by windrose »
Even when I roll the wick down it still wicks fuel up out of the top of the lantern. The only solution I have found is to let the fuel burn completely out each night.
Harry James
This is a brand new one on me. I have lamps sitting around the house waiting for a tree to take out the power, never any odor let alone liguid. I don't ever remember anything like that when I was a kid even with metal railroad lanterns that we use to use outside. Could you send me a digital picture of the lamp?
Matt B.
Boat Name: Firefly
Boat Type: Islander 28
Post by Matt B. »
windrose wrote:Even when I roll the wick down it still wicks fuel up out of the top of the lantern. The only solution I have found is to let the fuel burn completely out each night.
I used to have an oil lamp where the wick had to be rolled down to the very lowest point; no wick visible unless you looked straight down into the top of the lamp. With the wick in that position, it should be impossible to wick it out of the lamp. It might to the top of the wick, but that would still be inside the lamp.
Matt Beland
Islander 28 #256, SV Firefly
[email protected]
