David wrote:Are you planning a cuddy cabin of some sort also?
Whatever cabin there ends up being is entirerly dependent on what room is left over when the deck and cockpit has been constructed. This boat is to be all about the exterior: sailing functionality and pleasing aesthetics come WAY first, but there will assuredly be room for a basic cuddy cabin for storage, kids, etc. Whatever ends up being inside will be nicely finished, but basic in nature.
You can revisit my basic concept sketches here, to give you an idea how much potential space there will be forward of the cockpit.
Here are the most basic specifications that drive the ultimate design and construction:
1. Large, comfortable, and functional self-bailing cockpit
2. Cockpit and small cuddy cabin smoothly integrated of varnished wood
3. Clean, open deck spaces with lots of varnished wood and no unnecessary hardware
4. Engine room access beneath cockpit, most likely. Details TBA.
5. Deck construction of laminated mahogany beams with Meranti plywood sheathing (above a first layer of cosmetic beadboard facing down into cabin), with fiberglass overlay set in epoxy
6. Herreshoff interior appointments--painted panels and varnished trim, with exposed deck beams and beadboard overhead
Cruising sailors and weekenders need not apply. This is to be a boat intended for the pure enjoyment of sailing. There will be a discreet location intended for a Porta-Pottie.
To go any further than these basics at this point would be putting the cart before the horse. Too many of the final decisions remain unknown, as only once I begin building will the true relationship of spaces become evident. But these conceptual ideas are what I hope, and intend, to acheive.
