Steering Pedestal Upgrade
Maine Sail
Post by Maine Sail »
Hi All,
We bought a CS-36 earlier this season and it has a cockpit mounted main sheet traveler right in front of the pedestal. I did not want to switch to mid boom sheeting and therefore could not install an offset pedestal guard with Navpod's for the instruments. After giving this quite a bit of thought I came up with a method that works. I removed the pedestal guard top plate, bolted it to a piece of Starboard synthetic lumber duplicated the holes and then made myself a new top plate that was wide enough to hold two Navpod's on either side. It works perfectly and gives me a place for my depth, autopilot and GPS right at my finger tips. Making the top plate was very easy but the plastic wood "Starboard" is not very stiff so I supported it with two brackets made from 1 inch stainless steel dodger tubing and dodger parts. I know this topic comes up from time to time so here are some photos for ideas.
Before:
After:
Support Brackets:
Side View:
-Maine Sail
Canadian Sailcraft 36T
Casco Bay, ME
http://www.marinehowto.com
fusto
Boat Name: Erebus
Boat Type: Apollo 16
Post by fusto »
Wow!
That is some kind of slick setup.
Kudos.
Zachary
Adams, MA
