A shop with attached apartment. Perfect.
There was a very similar shop/garage home not far from where I used to live. So you're not alone in your thoughts. This one is 3 bays long.bcooke wrote:Actually, my ultimate home would be three bays wide instead of two. And there should be a deck off one end under which the Triton can spend the winter months under a permanent cover. Stairs on the inside would be better too.
Done? Never. Have you paid no attention here? :<)bcooke wrote:...my Triton will be done someday and no longer need a full working shop.
This is a good argument for an outdoor-only access to the living quarters, actually, since it would vastly limit the possibility of the shop-borne dust and smell entering the apartment. And the other issues can be dealt with up front with a bit of thought. A real problem, for sure, but one that can be successfully managed, I think.bcooke wrote:Living quarters over the shop are a problem. Smells, dust and that sort of thing.
Well, yes, but only from time to time. The reason for much of my slow progress (other than laziness and incompetence) is that I am trying to load all the heavy work up front on the project. I will always have something going on with the boat but hopefully the scale will diminish over time and the need for full indoor heated storage will fade with it. I can dream of a time when a month a year will cover the big stuff. Easy spring/ or fall stuff. Point taken though. The ability to bring the boat inside (I guess I need a trailer too) from time to time would be very nice.Done? Never. Have you paid no attention here? :<)
